Painted Intake - FirebirdV6.com/CamaroV6.com Message Board
Painted Intake
  • Painted Intake
    Just wanted to show what I did to my intake. I will send more when it is done. I wasn't sure if this should go in the engine or appearance, but here it is...
    Rob
    \"A one that isn\'t cold, is scarcely a one at all\" <a href=\"http://www.homestarrunner.com/sbemail.html\" target=\"_blank\">Strongbad</a>
    That looks awsome [img]smile.gif[/img]
    1994 White A4 Z/28<br />Mac Headers, Flowmaster, <br />1LE Intake Boot, TB Bypass,<br />TransGo Shift Kit<p>1995 3.4L A4 Camaro<br />K&N Intake, SLP Loudmouth Exhaust,<br />3.73 gears, B&M Shift Plus<br />30th Anniversary Racing Stripes<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=241488\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=241488</a> SOLD
      Hey thanks. I have a silver 95 Camaro and have burgandy stripes to put on. So the block is going to be silver with the burgandy intake. I hope it will look nice.
      I saw your car on your site, and shot you an email. Nice car.
      Rob
        I like that, it looks real nice, just make sure all the bolt heads you can see once its on the car are silver ;)
        [ August 23, 2003: Message edited by: wolf ]</p>
        Wolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
          Yup, painted intakes are COOL!!!!
          What type of paint are you using? I used the 1200* paint & clearcote
          2013 Ram 1500 Big Horn
          94 comero 3.4
            Yeah I am going to get those chrome caps for the bolt heads. They are a bit pricey, but they look great.
            With the paint, I couldn't find any high temp (1200°) for it so I used some moderate temp paint and clear coat for it (500°C). I have a friend that is trying to find a place to mix some burgandy high temp here in Germany. I did find some high temp for the block though.
            Like I said, I will post pics when it is done, should be in a week or two.
            Rob
            [ August 24, 2003: Message edited by: rt1 ]</p>
              Now post pics when you get her bolted back up.
              AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
                What kind of paint did u guys use so the heat wouldn't bother them.
                  Looks good (and in reality even better)! [img]smile.gif[/img]
                  <blockquote>quote:</font><hr>Originally posted by rt1:
                  I have a friend that is trying to find a place to mix some burgandy high temp here in Germany.<hr></blockquote>
                  I still do my best! ;)
                  At the moment it looks like germans only want yellow, red and green blocks/calipers/intakes...
                  <a href=\"http://www.hubraum-statt-spoiler.com/transamrims2.jpg\" target=\"_blank\"><br />1994 Yellow Firebird 3.4L V6 5spd</a><br />Borla, RandomTech Cat, Morroso CAI, MSD DIS-4, MSD coils,ported TB, TB Bypass, relocated IAT, 180° Thermo, Eibach Pro Kit, Bilstein HDs, ES bushings,RAM HD clutch
                    Birdman... you could use alot of caliper paint if you want. I used some high temp 'rattle can'. There is a wider selection of colors with spray paint. The prollem with the spray paint is that it usually not as high temp as caliper paint, but I don't think that my intake will ever get to 500°C, unless the engine is on fire, in which case I think that I would be f$^#ed anyway. Hope this helps.
                    Rob
                      <blockquote>quote:</font><hr>Originally posted by ChrisV6:
                      At the moment it looks like germans only want yellow, red and green blocks/calipers/intakes...<hr></blockquote>
                      Wow, green. Why didn't I think of that? Maybe a teal?
                      Rob
                        Thanks rt1. How much trouble is it to take the intake off.
                          Just the intake? I don't know, never did that before. Maybe someone else has. I know it's pretty easy when the engine is out though. I am doing this work along with a rebuild, so I have access to just about everything. I mean it's out, it should be painted.
                          Rob
