i had this idea of going out and buying some of that neon green wire (my car being green and all) and sticking it around the bowtie in my grill. i think that would look pretty at night. only problem i saw was getting the wire to the middle where the bowties at. i was thinking spray paint all but the part i want to glow black, then have it run out of the foglight hole and run along the top ledge and discreetly drop to the bowtie. i could make alot of friends with it.
