reverse indiglo gauge install - FirebirdV6.com/CamaroV6.com Message Board
This topic is closed.
  • reverse indiglo gauge install
    Has anyone installed reverse indiglo gauges in a 98 or newer camaro, i have a 2000 and i have no idea how to wire this thing, is it something you can do yourself or have a shop do it, the kit has everything you need but i dont know where to find the wires your supposed to use to wire this up any help would be appreaciated
    -----2k pewter camaro A4-----------<br />*Rk Sport Ram Air<br />*Bypassed Air Silencer<br />*2.5\" to 3\" cat-back exhaust<br />*3.42 LSD<br />*Racing Strips, rims, carbon fiber grill, painted interior
    how many wires can there be? dont you have to just wire in a power and a ground. i wired mine to the correct wire behind the headlight switch. find the power wire that comes on when you turn on your sidemarkers/corners (not headlights only... or the gauges wont come on when you just have on your sidemarksers/corners)
    Then just ground the other. have you gotten the kit yet? mine came with instructions.
    Visit My F-Body Page
      i have the kit and everything torn apart already. the kit has a power and a ground wire and thats it. i took the headlight selector and dimmer switch out but there are like 8 wires coming out of the headlight selector, which color wire is the power and which is a ground also some of the wires are bigger then the others, i just need to know which wires (i have no clue when it comes to wires so i cant tell if one is a power or not but they are colored
        moving to electronics
