Pewter 2K Formula ....step inside.... - FirebirdV6.com/CamaroV6.com Message Board
  • Pewter 2K Formula ....step inside....
    Hey man, i was just wondering where you got the pewter paint to paint your interior. Did you go to a shop and get them to make you some up in a spray bomb or what?, also did you use clear coat on it...can i just get the clear coat from like home depot or canadian tire or something like that? Also, can you use too much clear coat?
    99 Firebird Vert, Pewter Metalic<br />Fast Toys Ram Air<br />Jet Stage 2 Chip<br />17x8 Mille Miglia Emotion II Plus\'<br />wrapped in 245/35/17 Yokohama A520<br />Rhino Perf. Exhaust<br />K&N air filter<br />check pics at:<br /><a href=\"http://www.fastrides.com/members/v6birdy/\" target=\"_blank\">http://www.fastrides.com/members/v6birdy/</a>
    i believe pweter 2k is a lady. :D might want to edit the post.
    94 Firebird - Red A4<br /> <a href=\"http://members.cardomain.com/predatorbird\" target=\"_blank\">http://members.cardomain.com/predatorbird</a>
      Yepper...I'm a gal ;) I used Duplicolor's Pewter in the 11 oz spray can. It's the same paint GM uses and you can buy it at Wal-Mart. The number is #408 Pewter. :D I also used their clear coat. You can use too much clear coat at least that's what the painter then did my flames told me. you get it too high so it chips easily.
      -Michelle
      2000 Pewter Metallic Formula M6 <br /><br /><a href=\"http://flaminbird.smugmug.com\" target=\"_blank\">My 2000 Formula</a>
        Sorry mam, didnt know you was a lady..lol. Thanks for the reply. When i take my interior pecices off, should i sand them before i paint them? Thanks
          Its ok :D I'll forgive ya this time. Yes sand down the pieces before you paint with 400 grit. You also might want to use an Adhesion Promoter also made by Duplicolor. I had some trouble with my door panels and the paint ended up coming off!!
          :eek: I had to redo the whole panel and used the promoter. That did the trick! Its specially for plastic/flexible pieces. Check out Dupilcolor's website about it. This was also recommended to me by the painter that did my flames.
          http://www.duplicolor.com/products/adhesion.html
          [ March 14, 2003: Message edited by: Pewter2k Formula ]</p>
            and Might I say you did a wonderfull job on your car.. :D [img]graemlins/fluffy.gif[/img]
            Jeff ..
            1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
            2002 WS6 T/A.. Bolt ins..448rwhp
            2009 G8 GT.. Vararam intake, GXP axleback
            1998 Corvette.. Vararam intake, Ti axleback
            http://www.fquick.com/slow-v6
              <blockquote>quote:</font><hr>Originally posted by 1998silverbird:
              and Might I say you did a wonderfull job on your car.. :D [img]graemlins/fluffy.gif[/img] <hr></blockquote>
              Thanks :D
              • Andy H
                Transmission removal help!!
                by Andy H
              • 2.8 Bird
                Abs inop
                by 2.8 Bird
              • fishin
                by fishin
