high beam bulbs - FirebirdV6.com/CamaroV6.com Message Board
high beam bulbs
This topic is closed.
  • high beam bulbs
    i have some hyperwhite bulbs for my low beams on my 97 camaro. can someone tell me if this same bulb (9006) will also fit in the high beams? i am thinking of putting in four low beams and not having a high beam.
    <a href=\"http://www.cardomain.com/memberpage/483076\" target=\"_blank\">http://www.cardomain.com/memberpage/483076</a> <br />TSP rumbler, straight pipe, corvette servo. <br />Soon - 3.42+lsd,headers, cai,
    see my post below. $12 mod.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      i assume the bulbs are the same for the 98's as the 97's? well from looking at the link, it looks like you can modify a 9005 to fit a 9006, but not vice versa. i guess i'll figure it out when i get some bulbs in a week or so.
        they have the different connections so you cant connect a low to high,on the other hand you can cut the wires and switch them around
          Still trying to find oil leak
          2 days ago
          Getting some work done on my truck
