Removing Glue/Adhesive from Previousely Tinted Windows - FirebirdV6.com/CamaroV6.com Message Board
  • Removing Glue/Adhesive from Previousely Tinted Windows
    So, what do I use? [img]tongue.gif[/img]
    Tried goo-gone and turtle wax window cleaner. That stuff is STILL on there. Any ideas?
    2002 NBM Firehawk #312 | <a href=\"http://hawk.visionsconnect.com\" target=\"_blank\">hawk.visionsconnect.com</a>
    this will work:
    use this stuff called "GOO OFF" it's stronger han goo gone. (I got mine at k mart)
    Then use fine grain steel wool and soak the pad with it....
    then scrub away.
    Hope this helps.
    Joe
    *OneQuickSix*<br />1998 3.8L V-6 Camaro<br />~A4 w/Y87~
      Soapy water and a sharp razor blade
        i told you las time.. RUBBING ALCAHOL.. go to the grocery store.. its like $1...
        ~Billy
          <blockquote>quote:</font><hr>Originally posted by AllTheGoodNamesAreGone:
          ~Billy
          <hr></blockquote>
          [img]graemlins/thumbsup.gif[/img]
          Rubbing Alcohol + spray bottle + razor blade = no more adhesive.
          <b>Trucks</b> <br />\'05 Dodge 3500 Dually <i>Cummins Turbo Diesel</i><br />\'98 Dodge 2500 4x4 <i>360 V8 (Wife\'s)</i><br /><b>Toys</b><br />\'81 Chevy K10 <i>Stroker/Swampers/Custom Suspension/1-Tons/Beadlocks</i><br />\'99 Camaro Z28 <i>6 Spd, T-tops, Borla</i><br /><br /><b>Real trucks don\'t have spark plugs</b>
            Still trying to find oil leak
            2 days ago
            Getting some work done on my truck
