I tried forever to get those 3 clips off... they didnt come off, and i ended up ripping one up pretty good. I ended up changing the fog light from the front of the car with out taking the clips off. It was a PITA! Anyone who's changed on on a 93-97 will know what im talking about.
P.S. My hands look like they went through a paper shredder
[ February 27, 2002: Message edited by: Loochy88 ]</p>
the clips pull down. I usually put a flathead screwdrive under them to start prying down. Then needle nose pliers usually get em out. It's easy changing the bulbs. I can have the old ones out and new ones in in under 15 minutes.....U just have to know where you're reaching.
I wear surgical gloves so i don't have to worry about touching the bulb. I hold the bulb in one hand and use a free finger on the same hand that's not holding the bulb to guide the bulb into the hole. Once it's in you just turn it.
Thank God I'm not the only one. It took me two damn F*ing hours to figure out a way to get to the stupid thing, once I figured it out(Being that I had just bought the car 1 day before) it only took about 10 minutes. But for those two hours I hated myself. Just one of those, "WHAT THE HELL WERE THEY THINKING" things to me, but that is just me.
Davy Dave
94 Camaro AT 3.4L<br />Still working on something worth posting.
I've changed mine so many times that I can change them in about 5-10 min.... I just pop off the side pins, use an alan key to take off the assembly and change the bulb...
95 black camaro <BR>Alba eclipes wheels<BR>Dual flowmaster exhaust<BR>----->ZAINO<------
<blockquote>quote:</font><hr>Originally posted by 95blkcam: I've changed mine so many times that I can change them in about 5-10 min.... I just pop off the side pins, use an alan key to take off the assembly and change the bulb...<hr></blockquote>
That's from the front. I do it from underneath. That way i don't have to worry about messing the light up or it being out of alignment when I put it back on.
All you have to do to keep them aligned is to do one at a time. After you change the one side then get close to a wall or garage door and even them up.... Then do the other side. I hope this helps
I've tried that lining them up by pulling up to a garage door. What I find best for me is letting my girlfreind drive my car and i drive hers and we pass to see how it's shining. When i do ti from underneath the car, I don't have to re-adjust my lights :D
Okay, I think my car is different the everyone elses, I dont have anywhere to stick my hand to change the fog lamp, I put it on a lift today and there is a inch hole where the wires go into by the airbox and about 1/2 a inch by the washer tank I took all the screws and bolts off underneath but It didnt lead anywhere except underneath the airbox, I took all the screws off the front of the lamp and all it did was move it up and down. I dont undersatnd where you are sticking a flathead, I have no holes or clips for the screwdriver or anyway to get underneath, was the 97's different then the rest?
Dont call me chief.<br /><br />2001 Camaro Convertible Rs Replica<br />1991 Acura Legend
the front bumper cover attaches under the car with three plastic retainers. They push in and snap to hold. once you undo that there is a plastic piece of backing that you pull back and you reach towards the front of the bumper and feel for the wires. All camaros have it. just look a little harder.
(There are 3 round push up clips. They may resemble black plastic washers with a the push up piece being about the size of a pencil eraser tip. use needle nose pliers to pull it down and pull it out. The 3 push up clips are about 8"-1ft away from each other. If you look you will see them.)
