hey, i have a power steering leak. i put it on the lift at auto class but it was so dirty under there that we couldnt tell what was leaking. so i took it with my ramps to the car wash, while putting the car on the ramps i hit it with a little too much speed. i went off the far side of the ramps and the ramps hit under the car right behind the tires. the bottom of the fender is attached to that little plastic piece that says do not jack here. The bottom of the fender got horribly bent and now both fenders are way out of alignment with the doors. anyone had this happen? and can i just bend the bottom so that it realigns? I NEED ANSWERS QUICK PLEASE! thanks
both my fenders are bent
Damn that reallly sucks man.....I had a similar case when I had a ball joint pop...anyway the tow truck guy pulls it on the flat bed and when hes letting it down at the shop....the dumb@ss starts bending my fender since the wheel is only connected by the upper A-arm.....I can see the fender bending and I yell at him to stop.....he got pissed and said its broken and this is what happens when things break so I said well ur not gonna ruin my car to save you time....we ended up bolting the stripped ball joint on and changing it on with the spare...it held and we released it. You can barealy notice the bend no one has ever noticed it but me ... Im not sure if you can bend them back...fenders are about 157 a piece....Good luck1996 Firebird-Y87:SLP Cold Air Intake,Y87 Perf. Package: 3.42 Gears w/ Zexel-Torsen LSD, Sport Steering(14.4:1 ratio), Dual Exit Exhaust,800 watt Pioneer Amp and Two 10\' subs with a custom trunk enclosure.
Just get a big pair of plyers and go to town .
I went off a curb leaving a lot and hit mine, took 2 min to fix.Black 2000 Y87 Camaro with T-tops ,SLP bowtie grill, Suncoast Creations Ram air hood and air box,Hypertech pp3,magnaflow cat back,and hi flow cat. <a href=\"http://members.cardomain.com/sorn09\" target=\"_blank\">http://members.cardomain.com/sorn09</a>
Originally posted by Yaba3800:
sweet...even if they are really jacked though? problably and inch away from being flush withthe door
Anyhow, if you want to ghetto it, try using pliers or a dent puller and re-shape the fenders.
If you want it done correctly, either pull both fenders and hammer the dents out or just replace them.sigpic
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...2 weeks ago
