Removing Numbers from the Drag Strip - FirebirdV6.com/CamaroV6.com Message Board
  • Removing Numbers from the Drag Strip
    I've scrubbed the **** out of my window trying to remove the numbers that were put on it at the strip.. but i can't get the last of them off. I've been using windex, what else can i try to remove these numbers without scratching anything
    The numbers are on the rear window towards the front:
    <b><a href=\"http://www.cardomain.com/ride/2288859\" target=\"_blank\">1999 Mustang GT(Car Domain)</a><br /><a href=\"http://www.cardomain.com/ride/2123740\" target=\"_blank\">1998 Pontiac Firebird(Car Domain) *SOLD*</a></b> <br /><br /><a href=\"http://www.camarov6.com/cgi-bin/ultimatebb.cgi?ubb=get_topic;f=9;t=000902\" target=\"_blank\"><b>PA</b> - Maple Grove Test\'N\'Tune <i>April 15th</i></a>
    razor blade? just scrape gently. when i got my car, it had all the specs on it ( 1998,41K miles, ect ) and thats what i had to get it off. might be the same stuff.
      magnetic numbers [img]smile.gif[/img]
        or sticker decals.. ;) Don't know what kind of shoe polish they used.. but it looks potent. Super Clean will take care of that. Spray it on a rag first then wipe. Get some nice custom numbers made or get the package of letters/numbers from an auto parts store for the next outing. [img]smile.gif[/img]
        2004 CE Corvette 10.86@132mph
        2011 Cadillac CTS-V
        2006 Mitsubishi Eclipse GS
          rubbing alcohol, and a papertowel something that is somewhat course helps.
          Also a do-it-yourself carwash with pressure washing is good too.
            uhm.. its just shoe polish? should't it just wash off?
            /it just wipes off by hand on my car
            //doesn't understand
            99 WS6
            13.25@104.97 - Lid + soon to be more other stock items ;D
            Originally posted by camaroextra
            tears are great lube, but its hard to get a girl to cry onto her own ***.
              You let it hit the sun the next day and its really a ***** to remove.
              Honetly if any of you go to the track often do not use it. get magnets. my old car my glass ended up getting all scratched up, and I had little white flakes in my weatherstripping all over.
                lighter fluid
                1999 Firebird
                  Originally posted by SilverBirdSeven:
                  lighter fluid
                  be careful getting it near the weatherstripping might break down the glue.
                    I've been known to leave the numbers on my car for 2 weeks sometimes. Always comes right off with some Windex.
                    Yeah, that works pretty good. I've had to do that a couple times to get parking decal glue off.
                    Matt
                    1998 Mystic Teal Camaro M5
                      deff a razor blade.
                      WAWA-A-HOLIC
                        Before you use a razor blade like everyone said and scratch the $hit out of you're window, buy Goo Gone it's not too expensive it should remove that, also removes severe bug stains and tree sap/tar.
                        Good luck with that. [img]smile.gif[/img]
                        ---Niño---<br /><i>95\' silver 5 spd</i>
                          you hold the razor blade almost flat. it doesnt scratch the window at all. try rubbing alcohol if you dont wonna use a razor blade. but i would just use a razor blade
                            i've been scrubbing thehell out of it with windex and i removed the numebrs on the front of my car completly, but the back one won't come all the way off. I will try dabbing rubbing alcohol on a rag and using that, if that doesn't work i will move onto the razor blade.. thanks for the help
                              I detailed for a year, razor blade and windex will take off anything on your window
                              1999 Pontiac Trans Am M6 Far from stock.....
                              • Andy H
                                Transmission removal help!!
                                by Andy H
                              • 2.8 Bird
                                Abs inop
                                by 2.8 Bird
                              • fishin
                                by fishin
