Bolt on and lift off hoods - FirebirdV6.com/CamaroV6.com Message Board
  • Bolt on and lift off hoods
    Whats the difference betweek both?
    one uses the stock mounts, the other you need pins.
    2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
      I was looking at Jegs Magazine and I saw a 82-92 Camaro 3 inch cowl hood,I assume it will fit on a 82-92 Firebird also.It says it uses stock hinges and mounts and its a lift off hood.Sound right?
        dude, you just made an a$$ outa yourself. not me.
        comero hoods WILL NOT fit the Firebird. USes satock hinges & mounts, & is a lift off????? give us a part number. Lift of hoods are that, the lift off. Bolt on hoods use the stock latches, & BOLT onto teh stock hinges. they usually caost more because they are reinforced to use teh stock hardware.
        2013 Ram 1500 Big Horn
        94 comero 3.4
          Alright right dude...chill out...I didnt know much about hoods... :rolleyes:
            well damn, you're no fun [img]graemlins/stickpoke.gif[/img]
            [img]graemlins/wavey.gif[/img]
            94 comero 3.4
              Moving to appearance.
              www.RedLineVSix.com || 1996 Camaro, 15.159@92.5mph
                Who made an A$$ out of who? Can't even spell CAMARO on an F-Body board and the spelling is right in the address bar!
                Now moving on ... I did see a Firebird Ram Air hood (older style) on a camaro.
                Zaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>
                • Andy H
                  Transmission removal help!!
                  by Andy H
                • 2.8 Bird
                  Abs inop
                  by 2.8 Bird
                • fishin
                  by fishin
