interest in the bird of prey body kit? - FirebirdV6.com/CamaroV6.com Message Board
  • interest in the bird of prey body kit?
    recently i decided i wanted to spruce up the birds exterior. i saw the bird of prey body that gm used in a show
    http://www.spiceisle.com/glouison/Sp..._prey_2001.jpg
    http://www.autogazeta.com/c/8/b/2000..._of_prey-2.jpg
    and i decided it was perfect. i'm going to see what i can do to get this kit made in a group perchase from a someone and get some prices. would there be any interest in the body style in a kit for $750ish? let me know, if i can get enough interest i should be able to get this to happen.
    I dont that kit is made anywhere,i might be wrong though but i think it was just a one off for the show
    Dont call me chief.<br /><br />2001 Camaro Convertible Rs Replica<br />1991 Acura Legend
      I thought you were going boost?
        i am, but i have all the parts for the turbo already (including pipes) and im welding the pipes myself so there isnt really any more money involved in getting it done (just time).
        I'm not asking if i can buy the kit anywhere, im asking if i can get it made custom in a larger quantity (to lower the cost of each) would there be any interest in it from others here?
          Alright cool, what size turbo and what do you plan on running?
            well, im doing a twin vnt-25 turbo system (vnt is a type of vatn turbo) using a mocal scavange pump, twin saab 900 intercoolers, a bosch bov, and im going to try to tune it with 42*injectors a walbro 255 fuel pump and without an fmu. I will be running 6psi out of each turbo and im hoping for 12's after i get a set of abbott heads, a thicker set of mls head gaskets to lower my cr to 9.1:1 and a pnp intake manifold from them as well. its been a ***** recently to get the piping set up (it went well for a while but now im hitting some problems).
              that body kit is prett cool. if you can find it, i say get it [img]smile.gif[/img]
              2000 3.8 A4 Pewter Camaro
                i dont think its worth the money, there really isnt that huge of a change, unless you want the T/A look. removed front bird plate and changed the positions of the lower lights, some side skirts thats about it
                  Y not a FMIC?
                    i know the kit isnt very different than the stock ta but its a little different and not too over the top.
                    the reason for not going with a front mount ic is with two turbos a single dual inlet ic would have cost to much (i plan on upgrading to that later). the saabs are cheap and do their job pretty well. they will be mounted in the front corners with air dams under them to force air through them.
                    • Andy H
                      Transmission removal help!!
                      by Andy H
                    • 2.8 Bird
                      Abs inop
                      by 2.8 Bird
                    • fishin
                      by fishin
