There were some holes drilled in the front bumper cover by the previous owner for light covers. I removed the hardware and filled the holes in and sanded them.
The question is...I want to repaint this area black again. Should I primer first and then paint? And 2nd what brand of paint will work on this plastic.
We just did the Z28 that way. Mask it off and use primer first then Krylon Gloss Black. Compound then use 3M hand glaze and rub like mad. Should come out close to perfect.
Well got the job done. Used Kalyon primer and gloss black. Used 2000 grit paper to finish the surface.It came out pretty good for a first timer. I'll take pics tomorrow but will not post till after the show.
