Anybody know what I can get this from? website or local stores? Over the harsh winter we had water leaked in over my front bumper ground effects. So I have pieces of the double sided tape on both the inside of the ground effects panel and the outside of the car. I need to replace the double sided tape and fine a product to remove whats left of the old one. Thanks
ground effects adhesive tape.........
2002 Firebird Y87 & W68, A4, Magnaflow Exhaust, Whisper lid, K&N, 3.42 gears, LSD<br /><a href=\"http://www.cardomain.com/memberpage/770634/1\" target=\"_blank\">http://www.cardomain.com/memberpage/770634/1</a>Tags: None
yes, but make sure its the heavy duty stuff. dont just ask for 3m double sided tape, or youll probably end up with the 2 lb stuff you can hang posters with.
the stuff is expensive if i remember correctly. for a large roll it was like 15 or maybe even 20 bucks.
a much better bet than walmart would be a small shop that specializes in auto paints.
^ what he said..i have some in my tool box right now..i use it to mount thing instead of putting holes in the car..holds like concrete..it used to hold on the body kit i had..never failed..and its been holding on the mirror inserts under my hood for like over a year now..good stuff [img]smile.gif[/img]<b>12 SECOND DUAL STAGE DRY NITROUS POWERED 98 A4 V6 CAMARO<br /><a href=\"http://www.mysickcamaro.50megs.com\" target=\"_blank\">www.MySickCamaro.50megs.com</a><br />Best ET: 12.82@103<br />Best MPH: 104.7<br />Best 60\': 1.75 - Stock TC</b><br /> </font><blockquote><font size=\"1\" face=\"Verdana, Helvetica, sans-serif\">quote:</font><hr /><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">Originally posted by Shodown:<br /><strong>1DV6 runs 12\'s...enough said. </strong></font><hr /></blockquote><font size=\"2\" face=\"Verdana, Helvetica, sans-serif\">
Autozone also carries it...We can save a lot of time if you just assume I know everything...<br /><br />SXS Camaro - <br /> <a href=\"http://www.cardomain.com/memberpage/703383\" target=\"_blank\">http://www.cardomain.com/memberpage/703383</a> <br />or <a href=\"http://home.tampabay.rr.com/whitewrld/\" target=\"_blank\">http://home.tampabay.rr.com/whitewrld/</a>
I never heard of anybody using glue on a ground effect Nbajwill. Thanks for the info guys. I found the heavy duty stuff that you were talking about 18.95 for it. Couldn't find the bug and tar remover though. I did see goo gone but wasn't sure if it would work. Also how long till it holds tight? instant bond? or do you push the ground effect and hold it for a few minutes.2002 Firebird Y87 & W68, A4, Magnaflow Exhaust, Whisper lid, K&N, 3.42 gears, LSD<br /><a href=\"http://www.cardomain.com/memberpage/770634/1\" target=\"_blank\">http://www.cardomain.com/memberpage/770634/1</a>
Raven
yep, like i said. not cheap.
the tape will hold pretty much instantly. just hold it strongly in place there for a few seconds and let go. im sure you know you need screw on the ends of the gfx.
What I found works VERY well for adhering things like trim pieces is clear silicone caulk. It's waterproof, lets you position your piece because it takes time to set, and is a very strong adhesive. But if you really have to, you can still take the piece off down the road. Just use masking tape to hold the piece in place until the caulk sets.2002 Silver Firebird A4<br />T-Tops, Leather, Y87, W68, Chrome Wheels<br />Bone Stock
Originally posted by nda0602v6:
I would recommend using the tape on a really warm day or in a heated garage. That stuff doesn't seem to stick(bond) as good when it's cold
