Bad paint...... - FirebirdV6.com/CamaroV6.com Message Board
Bad paint......
  • Bad paint......
    The paint on the front of my car is peeling,right at the center of the nose below the grill opening, my question is has this happened to any of you and how old was your car when it happened?
    Also would this be covered under warranty? My car is only a year old with the factory paint, but it looks like it was sprayed to thick in this area,
    thanks in advance.
    99 Dodge Quadcab<br />Traded: 2001 Camaro(will be missed)<p>Be wary of anything that can bleed for 5 days and live....
    Warranty work.
    • Andy H
      Transmission removal help!!
      by Andy H
    • 2.8 Bird
      Abs inop
      by 2.8 Bird
    • fishin
      by fishin
