Ok, today i went out and bought replacement bulbs and tried to change them for my 99 firebird. I went under the car and noticed that a 3/8 is too small for the bolts and a 7/16 is too large? This is for my plastic covering. I was wondering, anyone have any suggestions on how to go along and gett hsi done?
help with replacing fog light bulbs
yea but do u have a firebird? you have the headlights int he way on the firebird. I guess I could always wait until i replace my headlight motorCar expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
i tried and tried, but nothign worked. For some reason, there are nuts behind it. I think some1 worked on it b4 and put the screws in wrong. I hate dumbasses like that. I'm just gonna drill the screws out and replace them.Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
put your car in ramps once up on both side on the bottom of the bumper there's 3 push pins pull them out once out u could pull on it and u be able to reach your foglights from behind and changed the bulb is very easy i done 3 times already. And for the bolt try using a 12 point socket it would do the trick. I hope this help<a href=\"http://img251.imageshack.us/my.php?image=familyhalloweenbird0011rs.jpg\" target=\"_blank\"></a>
