Can anyone point me in the right direction for this...?
I'm trying to get my headlights to stay off unless I actually turn the switch on...but I want just the fog lights,marker lights, and halos (I have black halo headlights) to run together...how can I do this???
#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
You can change the lower driving lamps to actual yellow fog
light by adding a yellow lens and from the underside of the
front of the car, put it in front of the lens of the lamp.
You can buy two for just $5 at parts-express.com, part no. 243-091. I have done it on my 2000 camaro and it works fine.
Umm, I didn't ask anything about a yellow fog light, lol... maybe I worded the question wrong...I meant, how can the automatic headlight become disabled??? Anyone else have halos that could possibly help?
like said by shock core, cut the wires, look on your dash where the vents are, you can either lift that up where the seam is and snip the wire, or pull your radio to go in from underneath, snip the wire, add some extensions and a switch like I did. Then if you want to use the autoheadlights, flip the switch to auto and they'll work like factory or switch it the other way and the car will think it's daylight. As for your halos and fog's and markers, all that you stated come on when you turn you headlight switch one click (parking lights) in order to make your halos come on with your parking lights - easiest way is ground them out and run a wire down to the positive wire from your foglights and wire tap it off of there. Then if you wish to get more creative, you can always hard wire the halos to a switch or wire them to your alarm system so they come on either with your alarm whilst the car is parked during day/night or to just a switch so you can turn them on at will at night or whenever you want to leave them on, and dont worry about your battery the leds in the halos will run for years off your cars battery. MIght be something you wanna look into.
what color is the wire that i'm sposed to cut??? I'm not too good with electrical work...I have the halos wired up with the fog lights already...now what about adding a switch to take away the auto daylight headlight so just the halos markers, and fogs are on?
so just cut it and that's it?? no more?? Sorry, but I just want to be TOTALLY sure before I CUT WIRES, LoL...So just cut one and my auto headlights won't come on??
Originally posted by unvmyrs: so just cut it and that's it?? no more?? Sorry, but I just want to be TOTALLY sure before I CUT WIRES, LoL...So just cut one and my auto headlights won't come on??
Disabling the Day Running lights and the Auto Headlight on feature is quite an easy mod and can be reversed just as easy. This mod takes approx. 10 min. and all the tools needed are a socket set.
1. Lift the trim plate from around the radio and climate control panel. No tools are needed as it is held on by pressure clips. Set it aside.
2. Take out the four hex screws holding in the radio in. (Note) You don’t need to disconnect the battery for this operation BUT if you do, make sure you know the code for your radio if it is enabled. You will need it to ensure your radio operates after putting it back in.
3. Move the radio aside and look into the dash. In the upper right corner on the firewall you will see a small black box with two wire harnesses attached to it (about the size of a pack of camels).
4. Lift the box in an upward motion, it’s on a slide clip. Bring the box out of the dash, there is plenty of wire to manage easily. Disconnect the wire harness with the BLUE wire in it, just let it hang out of the way. THAT’S IT!
5. Re-install the wire box, radio and faceplate.
this way you dont have to cut anything, but you will lose your drl's
Originally posted by PalmHarborBlkv6: You can change the lower driving lamps to actual yellow fog
Dude, i have been thinking to change my fog light to yellow...thanks for the great info...i was actually gonna spend $20 on a yellow bulb...but i am not sure what would look good..yellow , blue or purple ..any pics anyone.....thanks
Originally posted by kala: </font><blockquote>quote:</font><hr />Originally posted by PalmHarborBlkv6: You can change the lower driving lamps to actual yellow fog
Dude, i have been thinking to change my fog light to yellow...thanks for the great info...i was actually gonna spend $20 on a yellow bulb...but i am not sure what would look good..yellow , blue or purple ..any pics anyone.....thanks </font>[/QUOTE]I wouldn't do blue, should be a good way to get pulled over. Blue lights = illegal in most states (if not all)
Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
I am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...
