Okay so I'm working on removing some of my interior trim for some custom paint. I managed to remove the rear speaker grills because they have simple tabs holding them on. But the front ones will not come off. Do I have to remove the whole panel just to get the grills off? Second question is, under the grills there is a thin layer of gray paper, looks like its there so you can't see behind the grill, should I find a way to remove this before painting?
Front speaker grills
I dont know if anyone has this problem too. The front speaker grills have this cardboard cover around the outside edge. This cardboard overlaps a little onto the inner portion of the grill space so If you have a component set of speakers in your car, they will develop a little push in on the side of the rubber surrounds.
I did NOT have to take my entire door off to get the front grills out. They have 3 tabs and with a small screwdriver you can pop them out by prying. My back speaker covers were the PITA. I removed the felt behind the speaker covers so it would be easier to paint and handle and replaced with some black cloth.
GreenPunisher has a 97Zaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>
I have a 99 Camaro and my front speaker grilles were melted onto the door panel by the factory in addition to having the snap tabs. So I DID have to take my door panel off to get to my speakers and grilles. Now, if I were to cut the melted pieces off I could have them snap in like you did but I would have to first remove the door panel to get to those melted on pieces. I would not go all out with a screwdriver on the grilles. Break one and your sure to curse yourself more than you would if you were to just take the door panel off and look. Once you find out, make note of what you have and then you will know.
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...1 week ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...1 week ago
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...1 week ago
I stopped driving...2 weeks ago -
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...3 weeks ago
