ive seen this done b4 inside a firebird with red leds inside each of the air vents and it looked bad azz... i would like to do the samething... how is this setup done????
LEDs inside air vents question
If you buy your leds from www.oznium.com you get the resisor with it..Derek <br /><a href=\"http://www.cardomain.com/id/dmiller_2005\" target=\"_blank\">2002 Metallic Silver Camaro</a><br />35th Anniversary
All you need is a LED and a 470ohm 1/2 watt resistor.
solder the resistor on positive side of the LED and hook it up to any 12V power resources.1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
