Cool, I bought the same lights. The install is simple but time consuming because it's hard to get to that area. Just take your time or they will look like crap and have spaces showing around them. The light sits in kind of a "cradle" so you'll have to pull it up and then out. Of course you'll have to remove those black panels from under the nose to access the area. You'll also need a phillips screwdriver. I think there is 2 screws per light. Hope that helps. Here's a pic of what mine look like.
My Car: 1994 Camaro 3.4 V6 5-Speed<p><a href=\"http://www.cardomain.com/id/speedyman_2\" target=\"_blank\">My Car</a>
installing my clear corners was a bi*ch!!! i had to hack and cut a lot of the black styrofoam crap inside our bumpers. it wouldnt of been so hard if the cutting wasnt so akward to get to. took me some time, ok ok, a lot of time i didnt plan on taking. took me about 3 hours from under the car. just plan on using some sort of long, sharp blade to do some hacking before you even get the orange lights out. id say cut about a 3" block into the foam before you unscrew the origionals. the crap is dense too, so it will be a little difficult. but after you do all the cutting, the install should be easy. bulbs should come with the orange bulbs... mine did and i got em off ebay. i think they make the car look 1000 times better and accent the headlights a lot better that the stock orange ones. good luck and post some pics whan your done!
2001 camaro v6 red convertable<br /> ggotta go fast... I GGOTTTA GO FFAST! CCANT HEELP MMMYYSSELLLF<br />pics:<br /><a href=\"http://www.cardomain.com/id/darkthoughts5000\" target=\"_blank\">http://www.cardomain.com/id/darkthoughts5000</a>
First get the front end up, remove the front spoiler (air dam), on both sides unbolt the black plastic splash panels, look up and you will see the corner light assembly. Remove the two small bolts from the assembly. Gently twist out the bulbs from the assembly. Remove the light assembly by tilting it out. You may have to pull down on the flexible plastic tray the light assembly sites in to remove the assembly. It is a little tight.
To install the clear corners, simply reverse the process.
In terms of bulbs, I like Xenon gas filled bulbs.
2001 Camaro M5 Coupe(1 of 2,737), no options, Whisper Lid, K&N Air Filter, Free Ram Air, MAFS Screen removed, SLP Manual Fan Switch, 160 thermo, DEE\'s T/B Spacer, EGR Block-off plate, IAT resistor, CAI to EGR air feed, B&M Ripper Shifter, SLP Replacement Grill, T/A Exhaust, SLP five spoke take-off wheels, BMR strut-tower brace, BMR Tunnel Brace, BMR 32/21 front & rear sway bars with poly, BMR Poly/Combo Rear Control Arms, Clear front & rear corners, HPP3 modified 87 Octane program.<p><a href=\"http://www.cardomain.com/id/red2k1\" target=\"_blank\">http://www.cardomain.com/id/red2k1</a>
go to advance auto and get some apc super white 3157 and 194 bulbs, looks a lot better and its legal.
<blockquote>quote:</font><hr>Originally posted by FireFighter: go to advance auto and get some apc super white 3157 and 194 bulbs, looks a lot better and its legal.<hr></blockquote>
Are these lights white or more of a blueish color. You think they will look good on my red camaro? Since I'm going with blue accessories.
Wow, on 93-97 firebird years its easy, pop your headlights, remove the plastic around the light and squeeze your hand down, there is only 2 bolts [img]smile.gif[/img] I don't have clear corners, but I keep having to change bulbs, as the light on the right of my car keeps bursting
<a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=401701\" target=\"_blank\">3.4L Red Firebird</a>
I am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...
Building the Tom Henry RS Part 4: Suspension Mods, Tires, Wheels, Headers and other Cool Stuff. By: Hib Halverson
At the end of Part Three, we changed the valvetrain of the 3.8-liter V6 in the Tom Henry RS. We installed new, Yella Terra "Ultralite" 1.8:1, aluminum roller rocker arms, Katech valve springs and Katech titanium retainers on our 3800 Series II V6. Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...
02-07-2020, 11:30 PM
