Does any one know the replacement bulb i would need and how do i replace it. just take the dash off and cdplayer covor out?
help, the lights on my stock Cd player went out
98 silver 3.8 A4, cold air induction, K&N filter<br />Flowmaster 80 series muffler, 2.5\" pipes, Trans go shift kit<br />corvette servo, Big end performance trans cooler<br />:Apperance:<br />Chrome SS wheels, 4\" cowl induction hood, SS spoiler,<br /> Tint: 36% sides, 5% rear,<br />Rear camaro indention black, big bow tie in rear windowTags: None
Unfortunatly I do not have the part number for the bulb as I stole my replacement out of a friends 97 grand am. However I'm sure your local parts store can get you the right part.
However, to gain access to the bulb, remove the radio faceplate, there are 8? plastic tabs holding it on. Once loose, there is a single ribon cable connecting the face to the rest of the unit.
Once the face is free, examine it behind the display and you should see the bulb protected by a piece of white plastic. Twist the bulb 90 degrees and it should come out.
I've only seen the innards of the 96 & 97 delco units though, but hopefully this helps a little.
carldev1996 Firebird Y87<br />Dark Green
thanks alot98 silver 3.8 A4, cold air induction, K&N filter<br />Flowmaster 80 series muffler, 2.5\" pipes, Trans go shift kit<br />corvette servo, Big end performance trans cooler<br />:Apperance:<br />Chrome SS wheels, 4\" cowl induction hood, SS spoiler,<br /> Tint: 36% sides, 5% rear,<br />Rear camaro indention black, big bow tie in rear window
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...2 weeks ago
