rust removal?????? - FirebirdV6.com/CamaroV6.com Message Board
rust removal??????
  • rust removal??????
    I'm might gettin a 81 camaro soon for free. Unfourtanetly i hear the car has some rust on it.
    Is there anyway to stop or remove this rust??
    Thanks in advance
    1995 Camaro 3.4L<br />dynomax super turbo muffler<br />SLP CAI<p>It\'s red so it must be fast!!!
    sandpaper
    It depends on how deep the rust has gone through. Is it just a little rust or a lot?
    [ March 19, 2002: Message edited by: bu-bye ]</p>
    White 98 Camaro with t-tops leather and Y87. For more info on mods just ask.<br />1/4=14.9<br />2002 Xterra V6 A4
      some areas are worse than others, are there any fixes if it has rusted through?
        I had to cut out the rear quarter panel on my 77 when i had it. It was rusted to bad to do anything and i didn't want to leave the rust on to come back at a later time. If you can't sand it off cut it out as far as i'm concerned.
          what did you do after you cut out the rear panel?
            If it's just surface rust, wire wheel it and then get some Kent rust converter. It's the bomb. You can spray it on surface rust and it turns the rust black and preps it for primer. We use it all the time on stuff like door hinges and other hard to get to places. Here's what I usually do:
            1. wire wheel
            2. Kent rust convertor
            3. wire wheel again (just for good measure, to get the spots where the rust was too thick for the Kent stuff to get to)
            4. Kent rust convertor
            5. Self-etching primer (usually martin senior, sometimes PPG)
            6. Paint
            P.S. if you need to do any body filler work, be sure to do that BEFORE you use the self etching primer but AFTER the rust convertor. (make sure it's good and dry, too)
            Have fun!
            Maroon 1995 Camaro<br />No mods yet...<br />Lucky to have found this site!
              I support the cut it out, re-weld a new piece, sand, paint
              -Steve
