Has anybody ever taken that off?? I want to so i can put a black racing stripe on but i wanna leave that white. Im doing this tomorow so any help is really appreciated. Thanx
Front Firebird Emblem on 96 Bird ? Need answer ASAP!!
AIS 2 OHH the memories... Great times and putting names with faces.<p>From \"interesting\" hooters waitress(Did you guys FLY ? ) to pissing BMW owners off on the ride home. To ending up in Philidelphia and USING (hahaha) an ice machine. I had a BLAST.<p>Thanxs to all that showed up!!Tags: None
Heat it up with a hair dryer or something and take something to grip it with, I used plyers and slowly pull it off. Do not get it to hot or it will melt to the nose :( then you will need to take alchol or something to clean the exces glue off and you wont be able to tell it was ever there :D I didn't take the bird off, just the door letters but they are on there the same.97 Red Firebird<br />Best N/A 1/4: 13.98<br />Best N/A MPH: 96.13<br />Best Nitrous 1/4: 12.49<br />Best Nitrous MPH: 108.53<p>2001 Pewter Camaro SS <br />GTP Stage II Heads, Pig Cam, Holley Intake, SLP Headers, SLP Lid, Vigalante 3600 Stall Converter, MagnaFlow Cat Back Exhaust, Duel Electric Cut-Outs<br />11.26@121
Heat it up and take some fishing line and run it in between the emblem and the body and us it to "cut" the glue. Should come off pretty easily with no damage to either piece. Use WD-40 and alcohol to get the adhesive off. ;)2000 GTP<br />Thrasher CAI, 3.4\" pulley, DHP PCM<br />Member RedLineVSix<br />Best ET-14.02<br />Best Trap-97.15
Man, I was just thinking that. I am going to remove the front logo off my camaro before I paint it. I am going to fill it with body filler to make it nice and smooth up front. :D1996 Y87 Camaro, 175.0 rwhp, 211.6 rwtq.....1/4 15.500@88.54 <----- Needs work!!<br />-CAI, Custom bent S-Pipe, LS1 I-Pipe, Flowmaster 80 series, !MAF, manual fan switch, relocated trunk pop switch, 180 degree t-stat, More to come!<br /> <a href=\"http://camaro.wbisolutions.com\" target=\"_blank\">http://camaro.wbisolutions.com</a> <p>WANTED!!! Naked and handcuffed!
by DoodlerHi, everyone. We bought a 97 base model convertible Camaro and someone broke the motor ... Lights were blinking on the dash and that someone ignored the...2 days ago
by ssms5411Still trying to find oil leak on my Camaro, it’s a tough one. I think it is the oil pressure sender myself. Leaking when raving and going into boost....6 days ago
