vizage kit? - FirebirdV6.com/CamaroV6.com Message Board
vizage kit?
  • vizage kit?
    how much will the kit lower the body of the car? im planning on buying the kit this spring but i wanted to get lowering springs first but i need to know if the kit will lower the body alot cause the roads around were i live r crap and the r alot of places to scrap ur body. so if the kits lowers it too much, i can just go and spend the money some were else
    2000 3.8 A4 Pewter Camaro
    around 2" I think
    -Paul-<br /><br />03 Lancer Evolution VIII<br /><br />1998 Camaro M5 - Traded
      I have a 96 camaro with the vizage body kit. It is real low. I scrape in many places, and have had the front piece painted twice and i have to go back again. If you lower it and put on the body kit you will probably scrape everywhere. I would do one or the other, not both it will be too low. When i get time i will run outside and get a measurment for ya so you can decide for yourself.
      1996 V6 Camaro <br /><a href=\"http://www.cardomain.com/id/nexplicit15\" target=\"_blank\">http://www.cardomain.com/id/nexplicit15</a>
        thanks guys
          well, the kit is low like 98silver6 and NeXplicit15 said. i have it as well, and i scrape a little with no lowering springs. not as bad as xplicit... but enough to make u cringe when u hear the infamous noise weve all as f-body owners have heard.
          heres mine, basically, the sides and rear aint so bad... just the front really. hope the pic helps.
          2001 camaro v6 red convertable<br /> ggotta go fast... I GGOTTTA GO FFAST! CCANT HEELP MMMYYSSELLLF<br />pics:<br /><a href=\"http://www.cardomain.com/id/darkthoughts5000\" target=\"_blank\">http://www.cardomain.com/id/darkthoughts5000</a>
            damn, i guess if u cant see the pic i can email it to u. just give me an address.
              adromeda73099@msn.com
                I've got lowering springs and the wings west kit on my car, same idea at least. I usually only scrape when entering places with a steep angle, like driveways and parking lots that have those big angled entrances. The rest of the time it really isnt all that bad. Speedbumps and things like that you just have to take slowly and at an angle. My car has about enough ground clearance to slide a tennis shoe under if that helps to give you an idea. Just be drive carefully and be aware that you are lower and most things shouldnt give you much problems. Just has a slight learning curve.
                AIM: Alientr8tr<br /><a href=\"http://www.cardomain.com/memberpage/583450\" target=\"_blank\">1998 Camaro 3.8L</a><br />Flowmaster 80-series, !FRA, Eibach Springs, KYB AGX, SLP sway bars, 3.42/LSD, Wings West kit, Z06 Motorsports, Silverstone Metallic paint<br /><a href=\"http://www.shift5.com/\" target=\"_blank\">Shift 5</a> - My Band
                  always get the body kit on first before you lower the car, lower the car to much , then you might not be able to put a kit on at all. plus after the kit is on, then you will know exactly how much to lower it
                  <a href=\"http://www.cardomain.com/id/1loudv6\" target=\"_blank\">http://www.cardomain.com/id/1loudv6</a>
                    has anyone had problems with putting a jack under their cars? i do all of my car work myself so, i dont have anything else to lift my car with
                      http://f1.pg.photos.yahoo.com/ph/dar...&.dnm=5345.jpg
                      hopefully this link works
