gauges.... - FirebirdV6.com/CamaroV6.com Message Board
gauges....
  • gauges....
    i have a 2000 v6, is it possible to adjust the speedometer to work with the 150mph gauges? and if not, who sells any white face, reverse glow gauges for my car? this is after alot of searching [img]graemlins/popcorn.gif[/img]
    2000 3.8 A4 Pewter Camaro
    Umm I dont think reverse gauges are made for our cars, and if you wanted to get the 150 Z28 gauges you will need to find a whole cluster..
    http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEBWA%3AIT
    Derek <br /><a href=\"http://www.cardomain.com/id/dmiller_2005\" target=\"_blank\">2002 Metallic Silver Camaro</a><br />35th Anniversary
      well i know i'll have top get the whole thing but would it be possible yto adjust the needle to work with it? lik maybe adjust the computer?
        i dont think you can adjust the computer... but i think if you got some 2000 150 speedo from a camaro it would work. there was someone who did this on ths board and the swore that it was accurate as ever. the reason why i say get a 2000 is so that its the same year. doing a swap from a v6 to a ls1 is done the easiest with same year donors. so i think GM kept wiring and mechanical similarities between v6's and v8's. hope this helped a little.
        2001 camaro v6 red convertable<br /> ggotta go fast... I GGOTTTA GO FFAST! CCANT HEELP MMMYYSSELLLF<br />pics:<br /><a href=\"http://www.cardomain.com/id/darkthoughts5000\" target=\"_blank\">http://www.cardomain.com/id/darkthoughts5000</a>
          there is something you get to make it right.. Its like 80 dollars but I forget what its called!
            how dwould i go about doing this? would i just have to take off the face or what? what would i need to get to make it work?
              could you or anyone find out what it is called? it would be very appreciated
                all you would need is the whole gauge cluster assembly (its all one unit). the connection in the back of your gauges fits 5.7l models as well.
                  sweet!!! thanks
                    Originally posted by BLLDOGG:
                    sweet!!! thanks
                    Tach will be off....you need a dakota digital tach fixer to get it to read accurate. Speedo is on though.
                      i think Loochy has one of those corrector things on his car....
                        i have the jetscu2000... i use it to correct for my gears and tires. it corrects both the speedo and the tach, and i dont believe it would work for this application.
                        Visit My F-Body Page
                          Loochy, while we're here I want to ask you a question. I've heard some kind of rumor in one of the other discussions that the jetscu2000 for automatic cars can remove the speedlimiter, one guy was saying this at least. It probably isn't true, and the truth was never really answered. But I want to hear it from you?
