does anyone else have a foggy lense cover on their headlights? my left headlight cover has noticeable fog inside the lense, but the right cover is completely clear. Anyone know wut that is from or if they have it too? I have 100k on the car, and my brothers 98 grand prix has the same fog with over 100k miles as well
foggy headlight lenses
its just a normal thing alot of people have caused by mositure and ageing. you can take off the lense and clean and polish it up. do a search about how
Are you sure it's on the inside? If the headlight looks clear when you pour a little water over it, then it's the outside that needs to be sanded/polished.1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
Originally posted by camaro_98:
yea its definetly the inside, i guess its a normal thing that a cleaning will get rid of
i would suggest sanding them down, then polishing it up with some plasticx (or some good rubbing compound)
I did one of my headlights, and it looks alot better, but im far from done.
Re: foggy headlight lenses
Originally posted by victimizati0nits def. not on the inside if pouring water over it makes it go away.
lets do it cheap corporate philosophy...if it were made of glass.
none of us would be having this issue.Phil
Originally posted by PalmHarborBlkv6I just used a very fine sandpaper + Scrathc Remove Gs 27. Now the headlight plastic lens is WORSE. This is another example of GM
you sanded it down, and it is worse now?
go for a higher grit, and wetsand it.
if they were made of glass, they would be square, and our cars would look exactly like a 97
if you messed it up worse you must have done it wrong. i just got a bowl with warm water and some soap to put the sandpaper in and wetsanded with 600 grit then 1000 grit then 2000 grit then rubbing compound and mine look almost new. it just takes time and some elbow grease. i just made sure it was wet and i have heard with some soap in the water it kinda lubricates it when you are wet sanding. I done a couple lights that way and no problem like new. hope this helps98 Mystic Teal Camaro
Mods: FRA, K&N, Clears corners, runing lights, billet grille, All blue interior leds, All four highbeam mod, Halos
by FirebirdGTAll - sorry but there seems to be some glitches from moving to a new Host - hopefully they will be fixed soon.
If needed you can email me...1 week ago -
by LETZRIDEI am happy to announce that I have sold the site to Robert (FirebirdGT). Years ago this site went down when TealV6 had it, I bought it, refreshed it,...3 weeks ago
by LETZRIDE
Building the Tom Henry RS
Part 4: Suspension Mods, Tires, Wheels, Headers and other Cool Stuff.
By: Hib Halverson
At the end of Part Three, we changed the valvetrain of the 3.8-liter V6 in the Tom Henry RS. We installed new, Yella Terra "Ultralite" 1.8:1, aluminum roller rocker arms, Katech valve springs and Katech titanium retainers on our 3800 Series II V6.
Ultralites are nearly 25% lighter than the stock 1.6 rockers and 8% lighter than the SLP aluminum...02-07-2020, 11:30 PM
