T-top 3 guage piller pods fits !!!!!!! - FirebirdV6.com/CamaroV6.com Message Board
  • T-top 3 guage piller pods fits !!!!!!!
    took some time to install it today [img]smile.gif[/img] fits really well
    i just screwed it into the car instead of the PITA way OF attaching it to the stock pillar...... to many wires back there for that.
    it fits really easy this way [img]smile.gif[/img]
    www.turbov6camaro.com/3pod
    FUEL PSI
    WB O2
    BOOST PSI / VAC then you can see the boost controler and my shift light
    [ August 07, 2005, 12:07 AM: Message edited by: viper04af ]
    1997 3800 Series II Camaro
    nice... looks bad ***... bet it was a ***** though, not alot of room behind that pillar.
      woooot thats amazing lookin dude
      1994 Maroon Camaro<br /> <a href=\"http://www.cardomain.com/ride/2075062/1\" target=\"_blank\">http://www.cardomain.com/ride/2075062/1</a>
        mine attached nicely to the stock pillar. The 3 gauge pod is a pretty easy install really. What I did is connected the wires that were going to the same place in the pillar by soldering them in together so I only had my sensor wires, power wire, and ground wire coming out if the bottom in the dash. Fits really good.
        http://memimage.cardomain.net/member...96_55_full.jpg
        http://www.bowtiev6.com/
          Looks pretty awesome, have I mentioned that I am absoloutly in LOVE with the color of your car? Might I ask how much it cost?
            They really need to make one for my car :(
            -Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
              Andrew, can you take a pic of where the pillar ends? Since it is for a t-top it obviously must not cover the whole pillar, it's shorter length.
              Thanks
              ---Niño---<br /><i>95\' silver 5 spd</i>
                Thanks
                ok check the same link I added 3 pics for you... i just cut the mising part off my stock pillar...... also had to cut the top corner off the pods that or cut hole in the carpet..... our cars are the same shape so it fits perfect. without that the stock stuff under there there is plenty of room for wires
                  they dont make one for the 1996 ? how different can the pillar be? i cut the stock pillar out and just used this one
                    Thanks
                      i had to mod my pod too!
                      WAWA-A-HOLIC
                        http://www.dakotadigital.com/index.c...rod/prd332.htm &lt;&lt; my new boost gauge soon as it gets here [img]smile.gif[/img]
                          i have the dual one myself and really like it [img]smile.gif[/img]
                          N2O PSI
                          AFR &lt;--for looks ..soon to be WBO2
