how could i clean mine to make them all nice and clear again, there ****in gross, i used some orange clean ****, took some of it off, but i need some help, what do use? anything like house hold products i have alot of, but if i gotta go buy it i will, what to use....
STOCK HEADLIGHTS
I had the same problem.
Take out the headlights, get some fine grit sandpaper, and do a good wet sand on each of them. Start with something like 1000 grit. At first they will look real cloudy, but then you can work up to like 2000 grit paper. I did 1000 then 1600. Then get some plastic/headlight polish and polish them real good. Mine have looked better and better over time as I periodically polish them.1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
i would start at 2000grit with the sand paper presoaked in water and wet sand the light and then use some polish or scratch compound to finish it off.
