i recently bought clear corner lenses for my car. Havent really tried putting them in yet but just looking at it there seems to be alot in the way to get the old ones out and the new ones in. I really dont want to have to take anything apart to get them in. Any help or tips for making this install easier would be great.
clear corner lenses install
Hey here is the topic already rolling, I tried to answer this question before hopefully it helps. Also a lot of other people have helpful insight, good luck!
Clear Corner Reference
If not here it is again:
Well ok I just installed my clear corners on my '01 two weeks ago. I got my euro-diamonds off ebay from procarparts. I do not know what some of these people are referring to by cutting their bumpers and taking three hours etc. I did mine in 40 minutes tops. First thing I suggest is when you get them to buy some clear silicone and seal the whole clear corner. A lot of people have complained about them leaking so I did that the first day. To install them all I did was remove my headlight assembly all it is is two bolts and they are off. Once they are out of the way you can see the clear corners directly below. There were three screws/bolts that held mine in. Once removed and using a little persuation they came right out. Putting them in is the same thing, I went with the amber bulbs that were included because white bulbs are illegal here and there is no sense of getting pulled over for a 80 cent light bulb. Good luck with the install cause they definitely make the car look good!
[ June 30, 2003: Message edited by: rjazrs ]</p>-rjazrs<br /><a href=\"http://www.cardomain.com/id/rjazrs\" target=\"_blank\">2001 Chevrolet Camaro RS</a>
