I want to put red neons on both sides of the dash but I have absolutely no experiance in wiring stuff like that. Is there a website or can someone write detailed instructions as to how you wire them to come on when you turn your lights on? Or better yet how to wire them to a switch? Thanks in advance for your help.
Under-dash Neon questions
<a href=\"http://community.webshots.com/user/maniacls1\" target=\"_blank\"><b>2001 Firehawk #155 of 504 -M6</b></a><br />437 RWHP / 404 RWTQ -Dynojet (heads/cam)<br />12.34 @114 mph 1.7 60\' (bolt-ons only)<br />12.47 @116 mph 2.0 60\' (street tires, heads/cam)Tags: None
run the power from each to a single wire and run it to the switch then run both grounds to gether and ground it to a bolt under the dash that is not attatched to plastic i use the bolt on my shifter then run a constant power from the batt pr fuse box to the switch and waalaa done1998 Jet Black Trans-am M6 T-tops<br />\"Ask, and it shall be given you; seek, and ye shall find: knock and it shall be opened unto you:-Matthew 7:7<br />Old car<br /><a href=\"http://matthew27529.tripod.com/getsome\" target=\"_blank\">http://matthew27529.tripod.com/getsome</a><br />NEW CAR<br /><a href=\"http://garnerebel.tripod.com/\" target=\"_blank\">http://garnerebel.tripod.com/</a>
