Anyone know where I can find white face guages for a 95 firebird v6 automatic?
White Face Guages
McEwan (sp?) makes them....a friend of mine has them for his '95 V6 Camaro. Do a SEARCH over in APPEARANCE for it. Not sure how much it is.2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
You're actually looking for a speedo that reads 110, if I recall correctly. The speedo in your car has the marks up to 115, but only reads to 110. I'll check w/my friend about his & see what I can come up with.2001 Onyx Black Camaro M5-Totalled<br />2005 Ford F150 XLT 5.4L<br /><br />\"To make peace, prepare for war.\"
I bought mine from
http://hometown.aol.com/rmacewen1/
Like Fin said, if you have a 3.4, then the last number on the gauges is 110, but it reads to 115...the guages were 75.00 when i got them, but you are not actually buying the whole cluster, just overlays...but it looks good...
laterPurple 1995 Camaro<br />Moroso CAI, Flowmaster American Thunder Cat-Back, Coated Pace Setter Headers with custom built Y-pipe, NGK Plugs, Taylor Wires, B&M Shift Kit, ASP Crank and Alt. Pullies, Hypertech 160* Powerstat, TB Coolant Bypass, Custom Manuel Fan Switch, 17x9 Mille Miglia MM11-2 w/ Kuhmo ECSTA Supra 712\'s, Too Many Appearence Mods To List <p>Suspension: Complete Rear Drum to Rear Disc conversion (3.42 Gears, POSI), Eibach Pro-Kit(1.25\" drop), BMR Strut Tower Brace, BMR Adjustable PHR, BMR Lower Control Arms, 1LE Front Sway Bar, SS Rear Sway Bar, 1LE Driveshaft, Energy Suspension Bushings All Around<p><a href=\"http://www.geocities.com/MotorCity/Shop/9233\" target=\"_blank\">My Webpage</a> <br /><a href=\"http://www.worldwidecamaro.com/cgi-bin/ultimatebb.cgi?ubb=forum&f=33\" target=\"_blank\">Birmingham F-Body Assosication</a>
