ZO6 rims - FirebirdV6.com/CamaroV6.com Message Board
ZO6 rims
  • ZO6 rims
    Does anyone have any pictures of ZO6 Rims on a 4th generation firebird? They look badass I know on newer camaros but I've never seen them on our firebirds. Plus if I got 18x9.5 for front and 18x10.5 for rear what size tires should I get that wont cause fender rubbing? Or should I get 17 for front and 18 for rear?
    NO NOTHING CAR FAN
    http://www.bfranker.badz28.com/appea...ebird/z06b.jpg
    http://www.bfranker.badz28.com/appearance/ you can find just about anything you want there ;)
    Wolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
      stock tire size is 26.1 in. 275-35-18 tires are 25.57 in. you'll be fine in front. 275-40-18 is 26.6 in. i wouldn't lower the front of the car much if you get the second tire size, maybe 1/2 to 1 in. for the rears, 295-40-or 295-45 will be fine. these are 27.29 in. and 28.45 in. respectively.
        I don't plan on lowering the car at all theres not a lot of ground clearance in the first place. by the way do ya'll have a problem with scraping that little flap underneath the the front of the car. I always seem to scrape it when I turn into a slanted driveway or street.
        NO NOTHING CAR FAN
          That is what the flap is there for. That and to keep any rocks from sailing into your undercarriage. Once you get low profile tires on a 17inch rim, it will show off your fender gap a lot, making the tire look smaller. Here are what mine look like and youll see what I mean.
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
