how do you remove the back panel between the tail lights? anyone had to do this before?
back panel on camaro
If you take the taillights off which just involves unscrewing some plastic nuts inside the car then the center piece will come right off. I've had mine off numerous times and never had any trouble.1995 Pontiac Firebird 3.4L <br />TA front bumper, TA rear bumper, 98-02 Honeycomb tailights, GM Ram Air hood, 2k C5 18X9.5 Corvette rims all the way around, custom autoloc shaved handles, camaro two tone interior, silver badging, clear front marker lenses, RK sport headers, gutted cat, dynomax dual exhaust, Rear disc rearend, Richmond 3.73 gears, Zexel torsen LSD, Cross drilled front rotors, 2 12\" MTX thunder 8000s, Clarion 400W amp, MTX 5 1/4 <br />Components, thunder 4262 amp, pioneer head unit, Hypertech power programmer (Yes it does exist)
Yeah, its vary easy to do...i had mine off to put dynamat on it. Just pull back the carpet and it will pretty obvious how to get it out.<b>Matt</b><br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=377225&page=1\" target=\"_blank\">\'96 Camaro Z28 M6</a><br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=377225&page=3\" target=\"_blank\">\'96 Camaro M5</a>
I had mine off to cover it in black vinyl and will have it off again to paint it. There should be the black plastic pieces that hold the tail lights in and then there should be some nuts, 2 on each side. One on the very far outside and some further in. The outside ones are a bit of a pain to get to, a wrench is your best bet.1998 Red RS 3.8l A4<br /> Whisper - K&N - N20 - 1LE Panhard - Ghetto STB - 255/50ZR16 Ecsta<br /> Removed grille - Limo tint - blackouts - A-pillar cf a/f ratio<br /> Panasonic DF88 - 1 12\" Eclipse 88120.4 - Eclipse 3322 amp<p><a href=\"http://members.cardomain.com/raven_rs\" target=\"_blank\">http://members.cardomain.com/raven_rs</a>
