If you are just replacing a bulb on one side or something, unbolt the little black triangle of plastic under the car on the front, and unbolt the air dam and then put in the bulb. If you are putting in clear corners unbolt both black triangular shaped pieces and the air dam.
White 94 3.4 A4 Camaro<br />Perf:<a href=\"http://www.splmeter.com/94camaro.html\" target=\"_blank\">2.5\" Flowmaster catback </a>, K&N FIPK, B&M ShiftPlus, Aluminum Driveshaft<br />App: 17\" Eagle 077 wheels, rk sport performance spoiler, clear corners<br />Audio: <a href=\"http://www.splmeter.com/box.html\" target=\"_blank\">Drivers side 12\" stealth box</a><br />Times: 10.602@64.2 w/ 2.25 60\' in the 1/8th
1 day ago
