ok, so lambo doors dont work on camaros unless there is body work involved....right?
But what about putting the hinge on the other side of the door as like a suicide door, and having the front of the door open upwards ? I think that would be pretty nifty if someone did that.
#1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
oops, i spelled suicide wrong in the topic, my bad.
Just off the top of my head. You would need to reroute all the electronic that are in the door so they come through on the other side. Body work to clean up the old holes, body work to make the new wholes plus possible re-enforcment for that section of the body to be able to support the weight of the door without warping a panel, possible body work so the door would clear the body when it goes verticle, and think about the angle the door would have to hit so you could get in the car past the dash.
Some of that may not be actual issues, but you should think about them when you are planning.
same problem as the front. The fenders bulge out... :rolleyes: Plus wiring, plus the handle/lock assembly would be incredibly hard to use. Imagine opening our heavy doors upwards, its the same concept as to why door handles on normals doors (like the front door of a house) the handle is on the opposite side of the hinges.
Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
The front of the doors are rounded, so it would have to come out first. It could be done, but it would require far more work.
The hinging is VERY complicated, but I think Koenigsegg CC style doors would be the best answer for us. It would probably require a mechanical engineering degree and a broad imagination to even start on, though.
