I have a 99 y87 with ground effets. Since I bought the car I noticed that the are between where the front fender and ground effects meet, there is a BIG gap. I dont; raly know tha cause of this, but is tehr any way to fix this, possibly bending eeh fender back. I don't think it's the ground effects that are coming off, it looks more to be the fneder that is bent.
ground effects detaching?
well if you get tired of the GFX i'm interested in the front pieces. [img]smile.gif[/img]1999 Mildy Modified 3.8L V6 Mustang<br />everyone in the NC triangle area should check out the forums at...<br /> <a href=\"http://www.chaoscarclub.com\" target=\"_blank\">http://www.chaoscarclub.com</a>
Try some double-sided tape from 3M first. If that doesn't work, you may need to drill another screw or two up underneath to hold it flush to the fender.2004 CE Corvette 10.86@132mph
2011 Cadillac CTS-V
2006 Mitsubishi Eclipse GS
Originally posted by Chet Mo and the Camaro:
bmx u really need some gfx dont u!!!!1999 Mildy Modified 3.8L V6 Mustang<br />everyone in the NC triangle area should check out the forums at...<br /> <a href=\"http://www.chaoscarclub.com\" target=\"_blank\">http://www.chaoscarclub.com</a>
Are you sure the fender at the bottom is not flaring out from improper jacking? If you look at the bottom of the car you will see what looks like a pinch weld but it's not, it's the bottom of the fender and that is where it attaches to the car. It will say DO NOT JACK on it. But most people will not see that and jack it up anyways, causing the bottom of the fender to flare out and messing with the alignment of the ground effects too. Even if they hammer it back it might still be misaligned.1999 Pewter Camaro M5<br />Y87 Performance Package, Sport Appearance Package, Diamond Clears<br />Factory SS Hood, Free Ram Air Mod, Whisper Lid w/ K&N Air Filter<br />CarSound Cat 94009, B&B Tri-Flo w/ Quad Tips<br />BMR SFC, BMR STB, KVR Blank Rotors, Hawk HPS Pads<br />Black Painted Calipers w/ CAMARO Decal, 245/50 Dunlop SP Sport 5000<br />20% Rear 35% Side Tint, Red Reflective Inlays, Invincishield<br /><b>Young girls avert their eyes, weak men tremble, Ford dealers faint.</b>
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...2 weeks ago
