placement of sat antenna - FirebirdV6.com/CamaroV6.com Message Board
  • placement of sat antenna
    just wondering, could i place the sirius antenna on the back glass, instead of putting it on the roof and maybe damaging the paint?
    1997 3.8 5-speed Camaro<br />BMR STB, LCA\'s, SFC\'s,Panhard bar, Torque arm,1LE sway bars<br />Headers, SLP cold air, Flowmaster catback, takeoff LSD, Eibach pro springs<br />Hurst shifter, 01 Z28 guage cluster w/ white face overlays, billet grill w
    one guy I know put it under his hood, course he has a fiberglass hood.
    I'd consider seeing if I coudl run and some how put it underneath the spoiler. Since apparently it works through fiberglass.
    Actually if you have hardtop, coudl probably put above the headliner.
      I'm pretty sure my buddy has his on his Z28 right on top of the dash in the middle.
      Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
        im getting the siruis unit that you can take out your car, put in your house, or in a boom box. thanks for the help. i do have the hardtop, ill try that and see if it works, if not ill try to hide it as best as i can
          Cool, I'd pull the headliner and mount it on top fo the t-bar...
          not sure what your antennae looks like or how big it is.
          But I would mount it towards the middle of the roof. Right inside one of the weatherstripping channels here, and run the cable down through a pillar to whereever it has to go...
          inside view under the roof
            i've got mine under the hood. i have no problems whatsoever w/ the signal. of course i have a fiberglass hood. not sure if it works w/ a stock hood.
            94 Firebird - Red A4<br /> <a href=\"http://members.cardomain.com/predatorbird\" target=\"_blank\">http://members.cardomain.com/predatorbird</a>
              mine is between the t tops and the rear window in the middle.... .. works perfect, no problems.... this has been discussed serveral times in the stereo section... do a search
                I just stuck mine on one of those tie down hooks behind the back seat and ran the wire straight forward under the seat. The reception isn't bad, and I didn't want anything I couldn't remove easily because I have an XM MyFi that's pretty easy to move between cars.
                <a href=\"http://webpages.charter.net/camarov6/Car%20Pics/New/IMG_0085.jpg\" target=\"_blank\">Black 2002 Camaro M5</a>-SS takeoff muffler, B&M Ripper, K&N Filter, 35/20% tint, Infinity speakers, Viper alarm, perpetually breaking clutch return spring mod. 15.49@90.15<br /><a href=\"http://webpages.charter.net/camarov6/Car%20Pics/P14.JPG\" target=\"_blank\">Pewter 2002 Firebird M5 (Dad\'s Car)</a>
                  Mine is one of the older non-magnetic antennas. I secured it high on the back glass, just low enough so that there's no clearance problem when I pop the hatch. Works great. Been there nearly 2 years. Kinda has a shark's fin look to it.
                  1997 Camaro, Y87 Perf. Package, iRotor Drilled & Slotted Brakes, Bilstien Shocks, Custom drive shaft, K&N Filter, & Mobil 1 synthetic. 202+K miles and still drives like new.<br />-If you can\'t stomp \'em in the straights, kill \'em in the corners...
