BUMMER ENGINE PROBLEMS and hood question - FirebirdV6.com/CamaroV6.com Message Board
  • BUMMER ENGINE PROBLEMS and hood question
    Man, tell me if this sounds right...(and I know it is not appearance question, but I'll get to that in a minute...) My car, which you may or may not have seen...has 72000 miles on it, and i brought it to a chevy dealership and it has a damn blown head gasket!!! so they are going to fix it, which is 1300 dollars, and they are going to tune it up, flush EVERYTHING and clean EVERYTHING that holds liquid, swap all plugs etc...etc...which is 600 bucks...but they are going to replace all pushrods and bearings which is a 4-500 dollar value, for free. they said because they have a little wear on them....and they are doing a number of other things...( re-aiming headlights, rerunning my streetglow wires...hiding them I guess...replacing a missing screw on my bodykit...) for free as well...my question is why would it blow a head gasket??? this is going to be a 2300 dollar repair!!! it sucks too, and the reason is that the previous owner never gave it a 60000 mile servicing. I bought it at 62000, and the dealership just reset everything and told me it was all serviced...bastards. has anyone else ever had this problem with the head gasket??? my motor is torn apart as I type this...but i did get a free rental car, pontiac g6 sedan with the 3500 v6...
    and i want to do one last exterior appearance mod...an ss hood. I would feel guilty for just replacing a perfectly good hood...has anyone ever seen one of those ss hood scoops molded on? do they look good? i'd appreciate some feedback.
    #1:1999 pewter metallic y87 rs A4 camaro.check out the pics on the link below<br />#2:Bright red 1979 Pontiac Trans Am. Brand new 400 cubic inch Pontiac Motor. All work done by me, except the engine work.<br /> <a href=\"http://www.cardomain.com/ride/2216133\" target=\"_blank\">http://www.cardomain.com/ride/2216133</a>
    Re: BUMMER ENGINE PROBLEMS and hood question
    About your hood. I would just buy an SS hood instead of trying to mold an SS scoop on to your stock hood. You could keep your stock hood if something happens to your SS hood. Or you could try to sell your stock hood, I'm sure someone would buy it!
      why did you blow a head gasket? cause **** happens. its not cause your car didnt get a 60K service. hmmm, all this extra stuff sunds fishy but it might be so you agree to the large bill. Im really wondering about them changing your bearings. Im sure you might need them but I would ask to see them changed yourself and ask them about the condition of the crank. if your bearing are worn then your crank probably is too because of the coolant. they may be an honest shop but you can never be sure.
      2000 3.8 A4 Pewter Camaro
