Can you achieve a swirl-less finish?
I have found a 3000rpm unit and it is much cheaper than the Porter Cable unit.
I would think that with the same action I could achieve the same resaults, maybe at a slower rate. Any thoughts?
youve probably allready seen that, but just in case
- Dont stay in one place too long
- Don't use wool pads
i dont know how exactly it would compare to the porter cable. if used correctly, results would be comparable im sure. do you have a link to the exact unit you're looking at?
Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...
