Re-Calibrating the needles in gauges "or w/e you call it" - FirebirdV6.com/CamaroV6.com Message Board
  • Re-Calibrating the needles in gauges "or w/e you call it"
    I went to install my white overaly glow gauge today, everything went smooth.
    But when I went to drive it, the rpm needle started sticking like crazy.
    So of course I try to fix it, and it ends up being worse, and accidently pop out a few needles while I'm at it.... RPM needle, oil, temp, fuel :rant: stupid overaly
    anyways after about an hour i got them as close to as they were before I fuxored everything up. Is there something I can do to get them to there exact specs?
    Also the stupid overlay thing sticks to the gauges, what did you guys do to fix this?
    thanks... ****ty day
    Camaro V6 - 14.3 @ 96mph
    Camaro SS - cam/boltons/m6/tune
    http://www.crfhq.com
    Re: Re-Calibrating the needles in gauges "or w/e you call it"
    might be better in appearance where there are guys that does these swaps all the time. I am going to move it. I personally have no experience with overlays, so I am of no help to you
    http://www.bowtiev6.com/
      anyone :(
        the trick is, u have to put them on the car while its running.... yes........... turn the car off and let it sit for a good couple hours.... so the temp settings are legit........ now for the gas and oil, your gonna hve to guess.... u should know what your oil pressure usually is at idle and cool..... for the gas u might have to just fill her up and then put it on........ turn on the car and then apply them, when u turn it on they spin up to the propper locations..
          thanks, I think I got everything worked out, the temp might be a few degrees off but no big deal, thanks
            5 days ago
