Will this fit? - FirebirdV6.com/CamaroV6.com Message Board
Will this fit?
  • Will this fit?
    Will 98-02 z28 gauges plug right in and work in a v6 Camaro?
    I think they will but I wasn’t sheer so if u got any idea let me no.
    2000 “Grabber Orange” Camaro M5<br /><br />Pacesetter Headers and Y-pipe, <br />3” Cat,<br />3” Flowmaster cat-back Exhaust <br />SLP cold air intake lid,<br />K&N air filter,B&M Short Shifter, MSD wires,Hypertech Power programmer <br />-------------------<br /><br />\"Burn Rubber Not Soul\"
    Re: Will this fit?
    They should. I swapped the ones in my 95 with a 94 Z28, works fine. Except the tac is off. Someone said that I would have to swap a resister somewhere to fix it. I have an A4, doesn't bother me any.
    Rob
    \"A one that isn\'t cold, is scarcely a one at all\" <a href=\"http://www.homestarrunner.com/sbemail.html\" target=\"_blank\">Strongbad</a>
      Re: Will this fit?
      I'm guessing that you have a 98-02 model but you can put them in but your speedo will be off considering the difference from 120 to 150.
      2002 SOM 35th Camaro. K&N filter, smooth intake bellow, 160* thermo, \'vette power servo, B&M transpak, Pacesetter Headers, 3in. in dual 2.5in. out Flowmaster 40 muffler, custom dual side exit exhaust before rear tires, MSD plug wires
        Re: Will this fit?
        Rob
        What do you mean "the Tac is off" ?
        and how would any of the Tac or speedo be off? there still giting info from the same sensors
          Re: Will this fit?
          Correct, but the v6 guage only goes up to 125. The v8 speedo goes up to 150, so if you were going 70mph, it would say you are going about 115.
          Red 1998 Camaro<br />Mods so far=<br />K&N
            Re: Will this fit?
            the speedo shange is a 1:1.25 ratio so at 100mph your speedo will say 125mph . it will plug in and work just fine just have to recalibrate speedo. get a yellow box www.blackrobotics.com, thier are other options though not sure how many. i plan on doing this soon
              Re: Will this fit?
              putting z28 gauges in a v6 camaro is just as bad as someone putting z28 emblems on their v6.......you will never go 150 in it, why waste time.....just go buy a real z28.......just my opinion
              \"there are things known, and things unknown, and inbetween are the doors\"-jim morrison<br /><br /> <a href=\"http://www.cardomain.com/id/99NBMCamaro\" target=\"_blank\">http://www.cardomain.com/id/99NBMCamaro</a>
                Re: Will this fit?
                There are v6s on this board who could easily hit 150. :spank:
                  Re: Will this fit?
                  yea....a few....not the majority though
                    Re: Will this fit?
                    Just exhaust/intake they could probably hit 135-140.
                    • Andy H
                      Transmission removal help!!
                      by Andy H
                    • 2.8 Bird
                      Abs inop
                      by 2.8 Bird
                    • fishin
                      by fishin
