Need engine bay opinions - FirebirdV6.com/CamaroV6.com Message Board
  • Need engine bay opinions
    Here's what I've done so far:
    !Hood mat
    !Fuse box stickers
    !AIR and serpentine belt info stickers
    Black intake manifold lettering
    Polished A/C pieces
    Polished ABS brake lines
    Polished heater coolant line
    Relocated ground wires
    Whisper lid
    I need some ideas on what else to do.
    I'm planning on rerouting the passenger side spark plug wires around the backside of the engine so they're not sitting there on top of the intake. Also in the future is painting the upper intake and valve covers black and polish the ribs.
    I'd like to reroute those ugly pcm cables on the passenger side to somewhere less conspicuous. I know a couple people have done this from looking at the engine bay thread. How do you do this? Just tuck everything in there where the AC lines are?
    And finally, I need to replace some cracking wire looms. Does anyone think it should be a different color? Or should I stick with the black?
    So yeah, comments and suggestions solicited. ( I would put a banana man here but I'm only allowed 4 images lol)
    1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
    Re: Need engine bay opinions
    what you polished was not the A/c condensor. its the receiver drier. prolly the most common mistake i hear people call that can.
    Dave:
    00 Supercharged Camaro - RIP
    97 Turbo Camaro - Sold
      lol...fixed.
      Uh...so you stopped in to tell me I was wrong....but any suggestions?
        Looks like an engine bay...
        I suggest some heavy cleaning + some sort of polish or shine that actually makes it look shiny.
        Stick to looms that match the color of your car, nothing tacky, and nothings wrong with black looms.
        The PCM wire mod; just drill a hole in the wheel well area and route them down there and drill another whole where you want them to come out.
        At this point, your engine bay just looks like an engine bay. Looking at it, I wouldn't even notice the polished items.
        -Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
          look up the !pass wire mod. A lot of people do it, just drill a hole by your battery and by your PCM and then route the wires through the wheel well. There are some walkthroughs floating around here or on ls1tech about it.
          http://www.bowtiev6.com/
            You could try polishing the alternator and other things like loochy has done. Is engine bay looks great. Go look at that for ideas.
            -Travis-<br /><br />1999 Hugger Orange Camaro-stock<br /> <a href=\"http://www.cardomain.com/ride/763509\" target=\"_blank\">http://www.cardomain.com/ride/763509</a>
              I'd put some new black wire loom in there. maybe a battery cover... polished radiator cap??? I painted my air box base silver to match my car, and painted my washer fluid cap silver to match then went over the letters and washer symbol with a black sharpie. I think it looks good..
              Other than those suggestions just clean the little things that you think nobody will notice, because they will notice. Looks good right now, keep it up
                Wash it and Wax all the painted area! other then that looks good.
                  With your polished pieces..instead of black wire loom..do Chrome wire loom like loochy as done....nice accent piece...
                  30th Anniversary Camaro<br />White with platinum pearl w/metallic midnite blue racing stripes.<br />SLP CAI, Flowmaster exhaust, Taylor wires, NGK\'s, Streetglow Undercar neon (blue)<br /> <a href=\"http://www.cardomain.com/ride/1352101\" target=\"_blank\">http://www.cardomain.com/ride/1352101</a>
                    start off by cleaning and degreasing everything. i use regular household "fantastick" cleaner on most stuff. it cuts through the light grease and dirt. dirtier places will need heavier cleaners. your engine bay is never clean, so just keep wiping.
                    youre wire loom is old and falling apart in some places. replacing it, even with black, will make a big difference. when you do it, you could also reroute some wires to cut down on clutter.
                    the alternator and throttle body can be removed and polished without too much effort. it takes a dremel, some sandpaper, and some polish, but its easy to learn.
                    i chose to loose all stickers and i made a few of my own polished covers. you might try the same.
                    mainly though, just clean the heck out of it!
                    if you havn't, put some protectant on the hoses and other plastic parts to make them shine.
                    wash, polish, and wax the paint under the hood.
                    polished radiator covers look great if you can find one.
                    Visit My F-Body Page
                      :tup: Larry.
                      '95 3.8L A4 PGM. & '95 LT1 M6 PGM. :burn:
                        if you havent found that wire mod site yet, here it is, i have had this saved for the longest time, i want to do it to my car when i get the chance...
                        http://www.lswon.com/2005/01/25/wire-mod/
                          Thanks for the comments everyone!
                          I think I've decided on sticking with the original loom color.
                          Waxing the painted stuff is a good idea, I'll start doing that.
                          Loochy...you mentioned getting a radiator cover. I've got a 98; what kind of covers are offered for my car?
                            6 days ago
