I bought some black signal lights about 3 months ago and never got them installed and today I went to get them installed the mechanic told me he is gonna charge me 80 dollars I left because he only charged me 50 dollars to install my black halo headlights I think he is money hungry since I come to him all the time. So what I wanna know can I do this myself and what tools will I be needing to do this thanks
is there another option for me (black signal lights)
Re: is there another option for me (black signal lights)
are these turn signal light housings like black halos or something?
these turn signals are black and chrome just like my black halos and will look good when I get them on I bought them off ebay for about 25 bucks they are similiar to these http://cgi.ebay.com/ebaymotors/93-94...75565590QQrdZ1 but were cheaper and have chrome in the inside and I want to install them.
cool, i thought about getting some used once but i thought it would clash with my solid headlight cover. now since i have done the whistler mod, i wish i had picked them up. there should be a write up in the stickies on how to do it. it is supposidly had but i dont think so.
First, get a new mechanic. Installing halos is not worth 50 dollars and installing front signal lights is NOT worth 80 dollars.
Second, install your own clear corners. After doing it twice, I can completely swap my front signal lights in 10 minutes.
First, take out the headlight casing. Disconnect the 2 bulbs. There is 1 screw holding itthe casing in. I believe it's 9mm. Unfasten the screw, then slide the headlight out of the mount and pull it straight out towards the front of the car.
Now disconnect the 2 bubs going into the corner casing. Twist counterclockwise and pull them out. The corner casing is held in by 3 screws. 2 of them you get from the backside, and the last one is on the bottom. In spite of what people say, you can easily get the bottom screw out with a rachet. Then, pull the outside corner of the light casing up and in. You'll have a bit of a tight fit getting it to clear part of the bumper mount, but once you're past that, you're done. Reverse the process to install the new corner.
Like I said, I can do both of mine in 10 minutes.1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
very easy
http://forum.camarov6.com/showthread...corner+install
dude open your hood and look. headlights take 1 bolt each. and 3 on the turn signals its to easy i would not pay a mechanic even 5 bucks for this becouse its a joke. although i have rebuilt 3 totaled maros. . . trust me its easy youl be happy you did it
are the bolts a must because it looks like once you place the signals light in they are in already tight enough so are the bolts necessary the reason I am asking this because stock parts are put on with machines and I don't think I can remove these bolts buy hand if its possible what kind of tool will I need to do this
Yes, the bolts are necessary. ;)1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
