Engine/Engine bay cleaning - FirebirdV6.com/CamaroV6.com Message Board
  • Engine/Engine bay cleaning
    So here's my engine bay as it is now
    Pretty clean, but I want it cleaner. I degrease it every now and then then wash it off. Then something armor all the airbox setup.
    Anyways, I've heard of some people degreasing the whole engine, then spraying it down, and the whole bay with a pressure washer, is this safe/dangerous?
    Any other tips? thanks.
    Camaro V6 - 14.3 @ 96mph
    Camaro SS - cam/boltons/m6/tune
    http://www.crfhq.com
    Re: Engine/Engine bay cleaning
    Your engine looks really clean. I should clean mine up.
    -Travis-<br /><br />1999 Hugger Orange Camaro-stock<br /> <a href=\"http://www.cardomain.com/ride/763509\" target=\"_blank\">http://www.cardomain.com/ride/763509</a>
      pfff, the picture makes it look better than it really is, haha
      So is the pressure washing idea a good one or bad one?
        Engine looks good, Master Shake RULES, and where the hell is your hood???
          ? The hood is opened up... lol
            how do you clean yours??
            do you cover up the alt. or anything?
              I see it now. Got up too early with a mild hangover. Pictures didn't register too clearly in my nogin.
                :lmao:
                Red 1998 Camaro<br />Mods so far=<br />K&N
                  Probably dont want water in the ICM/Coils
                    alright i mgoing to try the pressure washer technique, it'll be super clean :)
                    and hopefully not super broken
                      pressure washer technique? Taylor, be careful man. Cover all electrical parts with plastic bags and the polished pieces with aluminum foil, if you're going to be adding water/liquids to the engine bay.
                      EDIT: found a site that might help you out.. "Degreasers and engine cleaners will strip your fresh finish off faster than a bug splatting against a windshield at 70 mph". Click Here :)
                      '95 3.8L A4 PGM. & '95 LT1 M6 PGM. :burn:
                        I've been using degreasers, and used water to spray down the engine bay, there's no harm, I'm just a little scared of pressurized water
                          Careful dude yoyu can really f up your engine bay it can cut rubber and atuly break plactic the water can force its self into place a hose cant get it. my brother bamaged the valve cover gasket on his old jaguar with my preasure wacher. it will take off paint on high setting
                            next week i let my engine dryice blasting:
                            http://www.maintenanceresources.com/...e_blasting.htm
                            here you see some bevore and after pix:
                            http://cgi.ebay.at/Trockeneisstrahle...QQcmdZViewItem
                            <i><b><br />1995 Convertible - - JUICED <br />There´s a difference between living and being alive - <a href=\"http://members.inode.at/christian.pichler\" target=\"_blank\">www.CLC1.de</a></b></i>
                              if you decide to pressure wash make sure you cover everything electrical, and use the widest spray patten. ive done it a couple of times with no problems, but use cation. be especially careful of any aftermarket electronics.
                              Visit My F-Body Page
