Well i did my calipers today i thoguht i would share. I just got pics of the actual calipers i will get a pic of them with the wheels on the car after i wash it next time. By then i should have my inlays and sail panels and my front emblem decals on. I will get it all done then get new pics.
Did my calipers today
Re: Did my calipers today
How long did it take you? (did you do 2 or 4 calipers?) I want to do mine, but I can't think of a day where I'll have all day to just paint the calipers.Black 1998 Camaro<br /> <a href=\"http://www.cardomain.com/ride/2300862\" target=\"_blank\">http://www.cardomain.com/ride/2300862</a>
mine took awhile. i took a dremel and sanded down and grinded off all the nasty grime that was on there. thats what took the most amoung of time. after that i put on 2 coats of primer, 3 coats of paint, put on the decals, and then put on 3 coats of clear on top of that. i let them sit for around 20-30 minutes in between each coat and once i was completely done i let it sit overnight just to make sure everything set up good. it took a long while but it was well worth it. i did it right the first time adn they came out looking really good.'99 Camaro Y87 M5 T-tops
Flowmaster american thunder cat back, 2.5" magnaflow high flow cat, centerforce dual friction clutch
Car Domain
Hell all i did was used a lot of brake cleaner and scrubbed the **** out of them, then straight to the first coat of high-temp red. No primer or sanding, i just did about 4 coats of paint and then 3 coats of clear and they still look good.Black \'94 Trans Am A4- SLP CAI & Loudmouth<br />Red \'93 Firebird A4- Ram Air under the WS6 hood, !cat, exhaust.
Originally posted by 99camaro-3.8mine took awhile. i took a dremel and sanded down and grinded off all the nasty grime that was on there. thats what took the most amoung of time. after that i put on 2 coats of primer, 3 coats of paint, put on the decals, and then put on 3 coats of clear on top of that. i let them sit for around 20-30 minutes in between each coat and once i was completely done i let it sit overnight just to make sure everything set up good. it took a long while but it was well worth it. i did it right the first time adn they came out looking really good.
im gonna do mine soon too, sence i have all the time in the world now being summer and all. your's look good, theres not many colors that would go with teal good. silver looks great.
EDIT: maybe i'll do mine in the next couple days, how many cans did you use? im assuming you did all 4 because 98's had 4 wheel disk's.Last edited by loser; 06-20-2006, 10:40 AM.1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
I used duplicolor caliper paint kit. It has everytihng you need it took me probably 4 hours and i left the wheels off overnight and let it set i might do the decals later because i got a lot of the paint left and i am planing on doin the rotors to putting the clear on. The kit i had was only paint.98 Mystic Teal Camaro
Mods: FRA, K&N, Clears corners, runing lights, billet grille, All blue interior leds, All four highbeam mod, Halos
Originally posted by Mystic98I used duplicolor caliper paint kit. It has everytihng you need it took me probably 4 hours and i left the wheels off overnight and let it set i might do the decals later because i got a lot of the paint left and i am planing on doin the rotors to putting the clear on. The kit i had was only paint.
so 2 cans will be plently?1998 bright red camaro ,M5 ,Y87 ,stock<br /><br />Originally posted by Rune:<br />If it smells like a turd and looks like a turd, chances are its probably not a candy bar.
Get the decals...it's only a few bucks and it makes your car look really custom.
Dont forget to spray clear over them though.1998 Camaro V6 \"Black Mamba\"<br />Y87<br />Whisper Lid w/ K&N filter<br />Flowmaster American Thunder<br />Numerous appearance mods.<br /> <a href=\"http://www.cardomain.com/ride/2154172\" target=\"_blank\">Car Domain</a>
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...4 weeks ago
