Question about Autometer Gauges - FirebirdV6.com/CamaroV6.com Message Board
  • Question about Autometer Gauges
    I have 2 autometer gauges....Both are cobalt and one is an A/F and the other is a voltmeter....I am trying to figure out how to install them?? All i have to do is connect red wire to battery and black to ground correct? On the A/F gauge i connect the violet wire to the signal wire on the 02 sensor...I know all of that but on my Voltmeter gauge it has the white wire for lumination...IF i connect that with the red wire it should power on with the lumination correct? I did that today and i dont get any illumination at all...Can someone help me! Can the illumination go out inside of the voltmeter gauge?
    Re: Question about Autometer Gauges
    anyone have an idea?
      Might try wiring it through the fuse that illuminates your dash lights, that way it will illuminate when you turn your lights on with the rest of your dash
      Custom interior...
      TEAM NoVa
        yeah i have it wired through the fuse box but illumination isnt working on it.....Do you know if the A/F gauge lights up at night with the cobalt series? I am wanting to know because at nighttime i cannot see my gauges because there is no illumination....??
          i quickly checked out my Cobalt A/F gauge the other night my touching it to the battery, I also noticed no illumination, only the blinking bar.
            so what is it then? Has your A/F ever lit up? Or is it just the blinking bars? I was told that the A/F would only blink those bars between rich, stoich and lean....Now my voltmeter the autometer tech people said that it should illuminate.....Mine doesnt so should i send it back in?
              i dont have it installed yet, but like I said, when I touched it to the battery there was no blue illumination, just the amber colored lean,stoich,rich bar.
