Best way to prevent rust? - FirebirdV6.com/CamaroV6.com Message Board
  • Best way to prevent rust?
    Whats the best way to prevent rust? I've heard of anti-rust chemicals
    out there. But I've heard wd-40 or paint will work fine?
    thanks
    Re: Best way to prevent rust?
    Where are you trying to prevent rust? A painted / well maintained surface is probably your best bet.
      is spray paint okay? I'm talking about anywhere.
        they do make stuff to stop and seal rust and they also make stuff to prep a surface to prevent rust then spray should work.
        2000 3.8 A4 Pewter Camaro
          Depends on the where the surface is.
          exterior body panels or visible areas - Primer and Paint
          rocker panels - Primer Paint and rockguard
          wheel wells and underbody - under coating
          interior panels or between panels - Spray on Corrosion inhibitor like LPS.
            yes, typically a primered and painted surface is all you need.
            Visit My F-Body Page
              POR-15.
              I just dip all my rusted parts in it.
              1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
                Originally posted by ChronoGN
                POR-15.
                The bar in back of the t tops -----about 5 inches wide from one side to the other has a design flaw (2000 camaro) and bubbles of rust appear.
                This is an example of GM just not giving a ****...they new this would happen...they could have spent 50 cents to spray that area inside to prevent the rust but GM has a philosophy of "how can we save costs, the customer be damned"
                Phil
