say you had a chrome bar, now you cut it in half to make it shorter. and we have a piece of ceader inside so the bar stays together. but the cut is still there. what can we do to fill in that slit?
chrome fill in
Re: chrome fill in
She has a bar with a cut in the middle. She wants to know how to cover up that cut so it looks like one piece again.
I have no clue what you could use as filler, but wouldn't look out of place on chrome. Sorry.
Re: chrome fill in
How deep is the cut? Is it just through the metal part?
You could always get a new chrome bar.
Whats this for anyway?
Originally posted by SSMOWS6i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
Still... 18-1 > 1 and done
Re: chrome fill in
Kristen,
It's an old school trick called brazing, or lead brazing. There are not a lot of people that know how to do it anymore. Basically what it is you have a peace of lead that you melt and form to your desired specs. A lot of old school hot rod shops might still do it. You will have to have it re-chromed but if done right you will never be able to tell it was done. They use it a lot for old grills for roadsters and mirror brackets and things of that nature. Not sure if that is what you’re after but maybe do a search on the net you might be lucky and find someone out there that still does it.2002 Firebird<br /> <a href=\"http://www.cardomain.com/ride/2106142/1\" target=\"_blank\">http://www.cardomain.com/ride/2106142/1</a>
Re: chrome fill in
Simple welding, and grinding would work here, depending on the metal and so-forth, but would still need to get re-chromedRebuilding the engine... Building a custom front end... T-top conversion... Custom rear hatch..
Custom interior...
TEAM NoVa
