Question: How do you fix a chip in your paint about the size of a lentil bean? Its on the hood if you have to know :(
I hate the highways here :(
Re: I hate the highways here :(
you can use touch up paint, fill it with the correct color, then wetsand it smooth, put some clear coat touch up over it if its big enough, wetsand again, polish, and wax.
ill admit, its harder than it sounds. try to work in as small of an area as you can. sanding is definitely the hardest part. after you fill in the chip start with about 800 grit in a small area, and go with that until the edges disappear around the chip. then put on the clear, and sand that up to 1500, then 2000. then polish and glaze/wax.
expect it to look better, but not perfect.:)
Thanks Loochy, your the best :)Originally posted by Loochy88you can use touch up paint, fill it with the correct color, then wetsand it smooth, put some clear coat touch up over it if its big enough, wetsand again, polish, and wax.
And a lentil bean is this big: O
R.I.P. '07 PatsOriginally posted by SSMOWS6i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
Still... 18-1 > 1 and done
