Right now I have reflective silver rear inserts. I just ordered ss mirror finish inserts. Does anyone have any suggestions for the removal of my current inserts? Yank them off, and use goo gone?
Removal of rear inserts
Re: Removal of rear inserts
a hair dryer would probably help lossen up then you could just peel them off with you finger nail. and just take some Alcohol or adhesive remover to make sure its clean. hope this helps98 Mystic Teal Camaro
Mods: FRA, K&N, Clears corners, runing lights, billet grille, All blue interior leds, All four highbeam mod, Halos
the easiest way is to get a blade, or a knife, and CAREFULLY try and peel it off.
if you dont want to do it that way, i would use something like goo-gone, or WD-40 and it should come off.
I dont know about goo gone, but i do know what WD eats paint, so dont keep it on for that long
i used goo gone when i took the side molding off my car and the paint was fine afterward.
But yeah i would jsut squirt some goo gone on there and let it sit for like 30 secs and then peel it off with some tweasers or something
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...4 weeks ago
