Does anybody know if i could install a z28 or any other 150 mph or higher gauge cluster into my 95 camaro?? it has the 3.8 v6, so it only shows up to like 115.. and i can bury the needle, so im just wondering if there is any way to put one in that reads higher.. if so, would i need some type of adapter or something for the wiring??
gauge swap
Re: gauge swap
yes, i have the optional 3.8, and yes, it does go about 120 or so.. but i will be removing the top speed limiter soon.. my friend has the exact same car and has the limiter removed, he claims to have hit 140 before, but that was in a 97 rs, where i believe they have a 150 mph speedo..
Re: gauge swap
Originally posted by 95camaro3800Does anybody know if i could install a z28 or any other 150 mph or higher gauge cluster into my 95 camaro?? it has the 3.8 v6, so it only shows up to like 115.. and i can bury the needle, so im just wondering if there is any way to put one in that reads higher.. if so, would i need some type of adapter or something for the wiring??
RobLast edited by rt1; 07-29-2006, 10:11 AM.\"A one that isn\'t cold, is scarcely a one at all\" <a href=\"http://www.homestarrunner.com/sbemail.html\" target=\"_blank\">Strongbad</a>
Re: gauge swap
97 still have the 125 speedo....ur top speed is 118 unless u up it or erase it....i have the 97 pcm in mine and i had it upped to 155...im not sure about the 95 pcms but i know the 96 i couldnt program it
87 Firebird RIP
96 Camaro RS RIP
94 Patriot Red 1LE Z28 - Sold
02 WS6 TA - Sold
Re: gauge swap
Originally posted by 01PewterDropTopDoes the Z-28 155mph cluster hook right up in a 125mph v6er place?
Rob\"A one that isn\'t cold, is scarcely a one at all\" <a href=\"http://www.homestarrunner.com/sbemail.html\" target=\"_blank\">Strongbad</a>
Re: gauge swap
Guage should swap OK. I put a TA guage in my 3.8 bird and it works fine. I even checked out through very crude calibration method that Speedo was readin gacurately.
Mine is a 96.96 Teal Firebird<br />Colchester, Essex, UK<br /><a href=\"http://www.centrestage.free-online.co.uk\" target=\"_blank\">www.centrestage.free-online.co.uk</a>
